klun
Junior Member level 2
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 // blowfish.h interface file for blowfish.cpp // _THE BLOWFISH ENCRYPTION ALGORITHM_ // by Bruce Schneier // Revised code--3/20/94 // Converted to C++ class 5/96, Jim Conger #define MAXKEYBYTES 56 // 448 bits max #define NPASS 16 // SBox passes #define DWORD unsigned long #define WORD unsigned short #define BYTE unsigned char class CBlowFish { private: DWORD * PArray ; DWORD (* SBoxes)[256]; void Blowfish_encipher (DWORD *xl, DWORD *xr) ; void Blowfish_decipher (DWORD *xl, DWORD *xr) ; public: CBlowFish () ; ~CBlowFish () ; void Initialize (BYTE key[], int keybytes) ; DWORD GetOutputLength (DWORD lInputLong) ; DWORD Encode (BYTE * pInput, BYTE * pOutput, DWORD lSize) ; void Decode (BYTE * pInput, BYTE * pOutput, DWORD lSize) ; } ; // choose a byte order for your hardware #define ORDER_DCBA // chosing Intel in this case #ifdef ORDER_DCBA // DCBA - little endian - intel union aword { DWORD dword; BYTE byte [4]; struct { unsigned int byte3:8; unsigned int byte2:8; unsigned int byte1:8; unsigned int byte0:8; } w; }; #endif #ifdef ORDER_ABCD // ABCD - big endian - motorola union aword { DWORD dword; BYTE byte [4]; struct { unsigned int byte0:8; unsigned int byte1:8; unsigned int byte2:8; unsigned int byte3:8; } w; }; #endif #ifdef ORDER_BADC // BADC - vax union aword { DWORD dword; BYTE byte [4]; struct { unsigned int byte1:8; unsigned int byte0:8; unsigned int byte3:8; unsigned int byte2:8; } w; }; #endif -------------------------------------------------------------------- // blowfish.cpp : Defines the entry point for the console application. // #include "stdafx.h" #include "blowfish.h" #include "blowfish.h2" // holds the random digit tables #define S(x,i) (SBoxes[i][x.w.byte##i]) #define bf_F(x) (((S(x,0) + S(x,1)) ^ S(x,2)) + S(x,3)) #define ROUND(a,b,n) (a.dword ^= bf_F(b) ^ PArray[n]) CBlowFish::CBlowFish () { PArray = new DWORD [18] ; SBoxes = new DWORD [4][256] ; } CBlowFish::~CBlowFish () { delete PArray ; delete [] SBoxes ; } // the low level (private) encryption function void CBlowFish::Blowfish_encipher (DWORD *xl, DWORD *xr) { union aword Xl, Xr ; Xl.dword = *xl ; Xr.dword = *xr ; Xl.dword ^= PArray [0]; ROUND (Xr, Xl, 1) ; ROUND (Xl, Xr, 2) ; ROUND (Xr, Xl, 3) ; ROUND (Xl, Xr, 4) ; ROUND (Xr, Xl, 5) ; ROUND (Xl, Xr, 6) ; ROUND (Xr, Xl, 7) ; ROUND (Xl, Xr, 8) ; ROUND (Xr, Xl, 9) ; ROUND (Xl, Xr, 10) ; ROUND (Xr, Xl, 11) ; ROUND (Xl, Xr, 12) ; ROUND (Xr, Xl, 13) ; ROUND (Xl, Xr, 14) ; ROUND (Xr, Xl, 15) ; ROUND (Xl, Xr, 16) ; Xr.dword ^= PArray [17] ; *xr = Xl.dword ; *xl = Xr.dword ; } // the low level (private) decryption function void CBlowFish::Blowfish_decipher (DWORD *xl, DWORD *xr) { union aword Xl ; union aword Xr ; Xl.dword = *xl ; Xr.dword = *xr ; Xl.dword ^= PArray [17] ; ROUND (Xr, Xl, 16) ; ROUND (Xl, Xr, 15) ; ROUND (Xr, Xl, 14) ; ROUND (Xl, Xr, 13) ; ROUND (Xr, Xl, 12) ; ROUND (Xl, Xr, 11) ; ROUND (Xr, Xl, 10) ; ROUND (Xl, Xr, 9) ; ROUND (Xr, Xl, 8) ; ROUND (Xl, Xr, 7) ; ROUND (Xr, Xl, 6) ; ROUND (Xl, Xr, 5) ; ROUND (Xr, Xl, 4) ; ROUND (Xl, Xr, 3) ; ROUND (Xr, Xl, 2) ; ROUND (Xl, Xr, 1) ; Xr.dword ^= PArray[0]; *xl = Xr.dword; *xr = Xl.dword; } // constructs the enctryption sieve void CBlowFish::Initialize (BYTE key[], int keybytes) { int i, j ; DWORD data, datal, datar ; union aword temp ; // first fill arrays from data tables for (i = 0 ; i < 18 ; i++) PArray [i] = bf_P [i] ; for (i = 0 ; i < 4 ; i++) { for (j = 0 ; j < 256 ; j++) SBoxes [i][j] = bf_S [i][j] ; } j = 0 ; for (i = 0 ; i < NPASS + 2 ; ++i) { temp.dword = 0 ; temp.w.byte0 = key[j]; temp.w.byte1 = key[(j+1) % keybytes] ; temp.w.byte2 = key[(j+2) % keybytes] ; temp.w.byte3 = key[(j+3) % keybytes] ; data = temp.dword ; PArray [i] ^= data ; j = (j + 4) % keybytes ; } datal = 0 ; datar = 0 ; for (i = 0 ; i < NPASS + 2 ; i += 2) { Blowfish_encipher (&datal, &datar) ; PArray [i] = datal ; PArray [i + 1] = datar ; } for (i = 0 ; i < 4 ; ++i) { for (j = 0 ; j < 256 ; j += 2) { Blowfish_encipher (&datal, &datar) ; SBoxes [i][j] = datal ; SBoxes [i][j + 1] = datar ; } } } // get output length, which must be even MOD 8 DWORD CBlowFish::GetOutputLength (DWORD lInputLong) { DWORD lVal ; lVal = lInputLong % 8 ; // find out if uneven number of bytes at the end if (lVal != 0) return lInputLong + 8 - lVal ; else return lInputLong ; } // Encode pIntput into pOutput. Input length in lSize. Returned value // is length of output which will be even MOD 8 bytes. Input buffer and // output buffer can be the same, but be sure buffer length is even MOD 8. DWORD CBlowFish::Encode (BYTE * pInput, BYTE * pOutput, DWORD lSize) { DWORD lCount, lOutSize, lGoodBytes ; BYTE *pi, *po ; int i, j ; int SameDest = (pInput == pOutput ? 1 : 0) ; lOutSize = GetOutputLength (lSize) ; for (lCount = 0 ; lCount < lOutSize ; lCount += 8) { if (SameDest) // if encoded data is being written into input buffer { if (lCount < lSize - 7) // if not dealing with uneven bytes at end { Blowfish_encipher ((DWORD *) pInput, (DWORD *) (pInput + 4)) ; } else // pad end of data with null bytes to complete encryption { po = pInput + lSize ; // point at byte past the end of actual data j = (int) (lOutSize - lSize) ; // number of bytes to set to null for (i = 0 ; i < j ; i++) *po++ = 0 ; Blowfish_encipher ((DWORD *) pInput, (DWORD *) (pInput + 4)) ; } pInput += 8 ; } else // output buffer not equal to input buffer, so must copy { // input to output buffer prior to encrypting if (lCount < lSize - 7) // if not dealing with uneven bytes at end { pi = pInput ; po = pOutput ; for (i = 0 ; i < 8 ; i++) // copy bytes to output *po++ = *pi++ ; Blowfish_encipher ((DWORD *) pOutput, // now encrypt them (DWORD *) (pOutput + 4)) ; } else // pad end of data with null bytes to complete encryption { lGoodBytes = lSize - lCount ; // number of remaining data bytes po = pOutput ; for (i = 0 ; i < (int) lGoodBytes ; i++) *po++ = *pInput++ ; for (j = i ; j < 8 ; j++) *po++ = 0 ; Blowfish_encipher ((DWORD *) pOutput, (DWORD *) (pOutput + 4)) ; } pInput += 8 ; pOutput += 8 ; } } return lOutSize ; } // Decode pIntput into pOutput. Input length in lSize. Input buffer and // output buffer can be the same, but be sure buffer length is even MOD 8. void CBlowFish::Decode (BYTE * pInput, BYTE * pOutput, DWORD lSize) { DWORD lCount ; BYTE *pi, *po ; int i ; int SameDest = (pInput == pOutput ? 1 : 0) ; for (lCount = 0 ; lCount < lSize ; lCount += 8) { if (SameDest) // if encoded data is being written into input buffer { Blowfish_decipher ((DWORD *) pInput, (DWORD *) (pInput + 4)) ; pInput += 8 ; } else // output buffer not equal to input buffer { // so copy input to output before decoding pi = pInput ; po = pOutput ; for (i = 0 ; i < 8 ; i++) *po++ = *pi++ ; Blowfish_decipher ((DWORD *) pOutput, (DWORD *) (pOutput + 4)) ; pInput += 8 ; pOutput += 8 ; } } } int _tmain(int argc, _TCHAR* argv[]) { return 0; }
Can someone tell me how to create an interface for the Blowfish code above? I want to show the execution time for the whole encryption and decryption process that is completed.
