Create Path showing DRC rules
relax4567
Newbie level 3
Newbie level 3
Hi
I am drawing the layout of my circuit using Virtuoso. I am using create path command to connect different blocks.
By mistake I pressed some key. Now, when I draw a path it shows the DRC rules ( like minimum metal width, minimum spacing) which makes the layout drawing easier.
I tried to figure out how I should setup the Virtuoso to do this but I could not.
I rally appreciate if someone can help me with this.
Thanks
May be this may help you?
