Create magnetic induction heat
babucr
Newbie level 2
Newbie level 2
Hai
I want to create heat using induction coil like one in induction stove.
I use the same round coil.I don't need any preset heats. So programmed IC is not required.
Is it possible to use variable resister (used fore fans regulator) for increasing heat?.
Thanks
Hai
Thanks
Hi
Your questions seems a bit general ! you need help , right ? so you must deliver proper and sufficient information !
Best Wishes
Goldsmith
You can use variable resister in PI circuits for power adjusting. Induction heat also needs a PLL to do frequency tracking.
You also can do power control in SW if you do it with DPLL.
