Oct 14, 2008 #1 J jayce3390 Full Member level 6 Joined May 22, 2007 Messages 351 Helped 29 Reputation 58 Reaction score 21 Trophy points 1,298 Activity points 3,287 Hi, I want to define a personnal function in ADS by using AEL file, this function is called in the dds file of the project. This function uses 3 parameters : Gain, compression and Pdel_dBm, which are computed from schematic by using usual equations (0.5*real(VxI*)....) I have to take these data as explain in the picture. But I encouter some difficulties to create this function. I give a jpeg picture to describe my problem, could you take a look for me? thank you for you help
