CRC explanation and coding
kit_714
Member level 4
crc calculation explanation
Hi all,
i am currently studying the principle of CRC-8 since i am handling the temperature sensor from Maxim (DS18S20).
Can anyone kindly explain the principle of this checking system?
The polynomial of CRC is x^8 + x^5 + x^4 + 1
and also, i found a source code about generating CRC-8 as follows:
BYTE by_ACRC8 ( BYTE byIn , BYTE bycrc)
BYTE i ;
for ( i = 0 , i < 8 , i++)
if ( ( byIn & 1) ^ ( bycrc & 0x 80 ) == 0 )
bycrc <<= 1 ;
else
bycrc = bycrc ^0x 18 ;
bycrc <<=1 ;
bycrc | = 1 ;
bycrc >>= 1 ;
return bycrc ;
2 questions for the coding...
1. bycrc = bycrc ^0x 18 .....what;s the operation for this line of coding?
2. Can anyone briefly explain the coding with CRC-8 operation principles?
Thanks in advanced.
Kit
crc explanation
Pretty good explanation here;
https://en.wikipedia.org/wiki/Cyclic_redundancy_check
I use the following assembly language algorithm for PIC microcontrollers;
;  Mike McLaren's Dallas one-wire 8-bit CRC code for the DS18B20
;  clear the CRC variable then run each byte from the scratchpad
;  read or ROM read operation through the CRC_Calc subroutine. A
;  final CRC value of '0' indicates "good data".
;    void CRC_Calc ()
;    { crc ^= IOByte;
;      for (i = 0; i < 8; i++)
;      { if (crc & 0x01)
;          crc = (crc >> 1) ^ 0x8C;
;        else
;          crc =  crc >> 1;
;  entry: IOByte contains data byte
;   exit: CRC contains cumulative CRC data
CRC_Calc
        movlw   d'8'            ;                                 |B0
        movwf   BitCtr          ; setup bit counter               |B0
        movf    owByte,W        ;                                 |B0
        xorwf   CRC,F           ;                                 |B0
        movlw   h'8C'           ; W = x8+x5+x4+1 polynomial       |B0
CRC_Next
        clrc                    ;                                 |B0
        rrf     CRC,F           ;                                 |B0
        skpnc                   ;                                 |B0
        xorwf   CRC,F           ; toggle b7, b3, and b2 bits      |B0
        decfsz  BitCtr,F        ; all done? yes, skip, else       |B0
        goto    CRC_Next        ; process the next IOByte bit     |B0
        return                  ;                                 |B0
crc_calc( )+pic
Thanks...
However...one more question...
What is the logical operation of the following code?
crc ^= IOByte;
Thanks in advanced first...
Kit
8 bit crc 8c dallas polynomial
That means : crc = crc XOR IOByte.
"^" is the symbol for logic xor in C language.
Regards,
Franck.
mike mclaren crc
Get it!
Thanks the help of you guys!
Kit
crc_calc()+pic
Here is the sample code i used for CRC calculation
#include <stdio.h>
#include <conio.h>
unsigned int checksum(unsigned char*,int);
void main()
unsigned int crc1=0;
int size1 =6;
unsigned char dpacket[6]={1,3,0,1,0,0x0a};
clrscr();
crc1 = checksum(dpacket,size1);
printf("crc = %X",crc1);
getch();
unsigned int checksum(unsigned char* dpacket1,int size)
unsigned int i,j;
unsigned int crc = 0xffff;
unsigned int poly = 0xa001;
for(i=0;i<size;i++)
crc^= dpacket1;
for(j=0;j<8;j++)
if(crc & 0x01)
crc >>=1;
crc ^= poly;
else
crc >>= 1;
return crc;
