Re: CRC Calculation
I went through this, too. The best help I found was in
https://www.modbus.org/docs/Modbus_over_serial_line_V1.pdf
... near the end there is 'C'-code for a CRC calculator.
Unfortunately, my need was for HCS08 assembly-code. For what it's worth, I have added it to this message.
Good luck.
Wade Hassler
; a 'Lookup-Table CRC Calculator' for Freescale 'S08
; MODBUS algorithm (poly=A001, initialize to FFFF)
; messages <256 chars
; no globals (except tables)
; adapted from
; "MODBUS over Serial Line V1.02" pg 43-44
; Calculate CRC16 of a string of bytes
; at entry:
; H:X-> string of characters
; A= length of string to be encoded
; at exit:
; H:X= CRC16
; A=?
CRC_INIT_VAL equ $FFFF ; spec says to initialize with this
;---- stack offsets for string-encode routine -----
CRCHigh_ set 1
CRCLow_ set 2
CRCLng_ set 3
CRCAdrH_ set 4
CRCAdrL_ set 5
Calc_CRC16:
;==== setup: performed once per calculation ===========
ais #-(CRCAdrL_) ; make space on stack for temporaries
sthx CRCAdrH_,sp ; save start-pointer
sta CRCLng_,sp ; save length-count
ldhx #CRC_INIT_VAL ; get initial-value and go
;==== loop: performed once per byte of message ========
CRCCalc_Loop:
sthx CRCHigh_,sp ; save current CRC at start of repeats
ldhx CRCAdrH_,sp ; point to next character
lda 0,x ; load next character
aix #1 ; increase address
sthx CRCAdrH_,sp ; save increased address
ldhx CRCHigh_,sp ; re-load CRC-so-far
bsr CRC16_Update ; put next character into CRC
dbnz CRCLng_,sp,CRCCalc_Loop ; repeat until finished
ais #(CRCAdrL_) ; fix stack before exit
rts
; Update CRC16 with one byte
; at entry
; HX = CRC so far
; A = byte to add to CRC
; at exit
; HX = updated CRC
; A = ?
;---- stack-offsets for byte-add routine ----
CRCInx_ set 1
CRCInp_ set 2
CRCHsf_ set 3
CRCLsf_ set 4
CRC16_Update:
ais #-(CRCLsf_) ; make room for temporaries
sta CRCInx_,sp ; temporarily save input here
sthx CRCHsf_,sp ; store CRCHigh,CRCLow
lda CRCInx_,sp ; get input byte
eor CRCLsf_,sp ; xor with CRCL
tax ; put index in X (H=0 : tables are 256-bytes long )
clrh ; this HX-pair is used for both lookups
lda CRCHsf_,sp ; merge in the low byte
eor CRCTbl_H,x
sta CRCLsf_,sp
lda CRCTbl_L,x ; get the high byte
sta CRCHsf_,sp
ldhx CRCHsf_,sp ; retrun the new CRC
ais #CRCLsf_ ; fix stack before leaving
rts
nolist
; Table of CRC values for high–order byte
CRCTbl_H:
fcb $00, $C1, $81, $40, $01, $C0, $80, $41, $01, $C0, $80, $41, $00, $C1, $81, $40
fcb $01, $C0, $80, $41, $00, $C1, $81, $40, $00, $C1, $81, $40, $01, $C0, $80, $41
; Table of CRC values for low–order byte
CRCTbl_L:
fcb $00, $C0, $C1, $01, $C3, $03, $02, $C2, $C6, $06, $07, $C7, $05, $C5, $C4, $04
fcb $CC, $0C, $0D, $CD, $0F, $CF, $CE, $0E, $0A, $CA, $CB, $0B, $C9, $09, $08, $C8
fcb $D8, $18, $19, $D9, $1B, $DB, $DA, $1A, $1E, $DE, $DF, $1F, $DD, $1D, $1C, $DC
fcb $14, $D4, $D5, $15, $D7, $17, $16, $D6, $D2, $12, $13, $D3, $11, $D1, $D0, $10
fcb $F0, $30, $31, $F1, $33, $F3, $F2, $32, $36, $F6, $F7, $37, $F5, $35, $34, $F4
fcb $3C, $FC, $FD, $3D, $FF, $3F, $3E, $FE, $FA, $3A, $3B, $FB, $39, $F9, $F8, $38
fcb $28, $E8, $E9, $29, $EB, $2B, $2A, $EA, $EE, $2E, $2F, $EF, $2D, $ED, $EC, $2C
fcb $E4, $24, $25, $E5, $27, $E7, $E6, $26, $22, $E2, $E3, $23, $E1, $21, $20, $E0
fcb $A0, $60, $61, $A1, $63, $A3, $A2, $62, $66, $A6, $A7, $67, $A5, $65, $64, $A4
fcb $6C, $AC, $AD, $6D, $AF, $6F, $6E, $AE, $AA, $6A, $6B, $AB, $69, $A9, $A8, $68
fcb $78, $B8, $B9, $79, $BB, $7B, $7A, $BA, $BE, $7E, $7F, $BF, $7D, $BD, $BC, $7C
fcb $B4, $74, $75, $B5, $77, $B7, $B6, $76, $72, $B2, $B3, $73, $B1, $71, $70, $B0
fcb $50, $90, $91, $51, $93, $53, $52, $92, $96, $56, $57, $97, $55, $95, $94, $54
fcb $9C, $5C, $5D, $9D, $5F, $9F, $9E, $5E, $5A, $9A, $9B, $5B, $99, $59, $58, $98
fcb $88, $48, $49, $89, $4B, $8B, $8A, $4A, $4E, $8E, $8F, $4F, $8D, $4D, $4C, $8C
fcb $44, $84, $85, $45, $87, $47, $46, $86, $82, $42, $43, $83, $41, $81, $80, $40
list
