Who do you mean? And which wrong information? Please kindly express.hi
i dont know why some one with out enough knowledge interfered in every thing...
and pls didn't give wrong information to others
hi icpinu
first: every one know that the Maxwell equation is base of antenna design and simulation and its not alter in material or frequency and solution method that u chosen. so that awfully some one said cpw impossible in one frequency .
second:for increase gain every one can said array method but its not merit of designer when a person design an antenna element with high gain its a merit.
third : UWB usually needs in every new system and every one knows the benefits of UWB antenna and system
at last i should add that design antenna at 60 GHz frequency not hard but fabrication is hard if u dont have enough support and u can use many material at that frequency like material with silicon structure or ceramics and polymers
