CPW coplanar waveguide circuit design
icpinu
Junior Member level 2
This might be a very easy question but I don't have an idea on where to start with CPW circuit design.
I have been using ADS to design a microstrip circuit since it has Tlines components where you can actually select for a BPF design the characteristics of it and it will give you all the dimensions of the design based on the characteristics of your substrate.
This option as far as I know is not available for CPW, it is for waveguides and striplines. So I don't know how to design a CPW. It seems that from equations it could take ages to design a simple detector circuit.
Any tips would be very useful. The idea that I have is that maybe I could do the circuit design in microstrip and somehow modify that initial design to CPW.
Thanks for your help.
I also faced this problem with the limited CPW library in schematic. I got used to work directly in Momentum to simulate coplanar structures.
I am also interested in a solution for a more extensive library in schematic.
Thanks for your reply
can you describe briefly the design process you follow in momentum for a BPF or other design.
Many thanks
There are two ways to design CPW in Momentum:
1- map metal as strip and use differential ports
2- map metal as slot and use coplanar ports
in 2nd case you actually only draw the gap between the lines and stimulate the gaps with the coplanar ports. This is a bit confusing the very first time but way faster regarding computing time.
Then I draw the structure and let the optimizer doing its job with the standard parameters or perturbation optimization. One critical point if you don't have a grounded CPW is the air-bridge. I never had to optimize with air-bridges.
Reactions: icpinu
    icpinu
Hi thanks a lot.
Could I use as a starting design tools for microstrip to design for example an impedance matching circuit and then follow your design methodology?
Also, another beginner question if I have a conductor backed cpw do I still need air bridges?
Thanks again
hi every one ....
can u send how to design and simulate the coplanar waveguide structure in cst studio.....
thank u
U can take the help provided in the CST itself as it contain lot of examples which are simulated.
