CPU (SoC) with Ethernet, 2 x RS232, SPI, JTAG
dainis
spi ethernet
I am looking for any replacement for Am186ED + CS8900. (Because Am186ED stay obsolute)
Solution is preferable SIMPLE and LOW COST SoC with:
Ethernet 10Base-T (also 10/100Base-T is ok),
2 normal hardware UARTS (RS232),
2 x I2C (it is sufficient to emulate it by software)
1 x SPI (Sync full duplex serial controller, also sufficient software emulation, but preferable hardware)
JTAG port, for Flash ROM programming, not bad for Debugging.
same IO pins for simple keypad, 2x16 LCD, LEDs e.t.c
Thanks.
cpu soc
what about embeded ethernet toolkit from atmel ??
look at ***.avrfreaks.com
reagrds
Cancel
low cost cpu spi
Really I need more powerfull (in MIPS and RAM size) device, than AVRs or other
8 bit CPU and need many TCP/IP protocol support (WWW,Telnet,SNMP,SLIP, RIP V2,TFTP ...)
dual ethernet soc
there exist simm like modules from m*t*r*la ... unfortunatelly i do not know the p/n
have a fun
cancel
universal jtag
What you are looking for is a motorola 360 for 68000 type uc or motorola 860 for ppc type uc. Both have a risc coprocessor that adds spi, ethernet, serial,... type functions.
mac loopback in mcf5282
Motorola coldfire 5272, 5307 .....
Mabe can do this.
jtag cpu - spi
Maybe it's not exactly what are you looking for , but worth take a look.
www.lantronix.com/products/eds/dstni/index.html
www.ubicom.com/products/ip2000/processor/ip2000_processor.html
www.connectone.com/html/ilan.htm
www.rabbitsemiconductor.com/products/rab30/index.html
www.lillfab.se/boards/cpus/EnCore_M2/EnCore_M2.html
If for them it's not obsolete and still able to deliver:
and many other involved in Am186 with ethernet support. Look inside huge list:
and another ones willing to help you replace the obsolete Am186:
www.realtime-info.be/vpr/layout/display/pr.asp?PRID=2796
w90n740 idle
Thanks.
This is one of real candidate.
Other real candidate is ARM based CIRRUS LOGIC CS89712.
This has very limited ram (vithout external) and do not SNMP protocol stack.
We always using other Scenix (UBICOM) SX28 and SX52 microcontrollers, up to 5 in one device :)
Not all requred features.
External ethernet and no SNMP stack.
Alchemy Au1000TM CPU is powerfull, but may be expeensive.
>>h**p://www.xecom.com/Pages/Closeup.cfm?ID=131
This is like, that we using in self made board.
>>h**p://ethernet.for-industry.com/products.asp
This is link of complete controllers and boards.
... with production available for testing in the third quarter 2002,
but I need it today :(
jtag cpu spi
Samsung's netmcu is the best replacement for your AMD
s3c4510b netmcu includes components what you need except spi
but it is easy to get via a serial port
dos zfx86 i2c
Hi Big&china,
I'm very interested in Samsung devices (like S3F441FX, a ARM7TDMI all in flash), but where to buy it? I can't find a place in the World to buy small quantities.
ThX
NeuralC
rs232 to jtag
ATMEL is going to deliver the ARM920T core-based chip Thunder with a Ethernet MAC 10/100 interface, 4 usart, SPI port and lots of I/O.
ethernet spi soc
Processor Core
* 32 bit CPU core
* 8K cache
* Floating point unit (FPU)
* Level one write back and write through cache support
DRAM Controller
* SDRAM (Synchronous DRAM) support
* Memory configurations to a 32 bit or 16 bit data interface in up to four memory banks
* 16/64/128 Mb symmetric or asymmetric SDRAM
* Maximum 256MB memory space
PCI Host Bridge Controller
* 32 bit 33MHz rev. 2.1 compliant
* Bus speed is system clock or system clock/2
* Burst transfers up to 120MB per second
* South Bridge and external masters can access SDRAM connected to DRAM controller
* Supports up to three external PCI masters
Full ISA Bus
* Full set of ISA bus signals
* Complete IRQ set
* 16 and 8 bit DMA support
* 16 and 8 bit device support; full set of control lines
IDE Controller
* Support two channels with 4 devices
* PCI master burst reads and writes
* Ultra DMA (ATA-4) support
* Programmed IO (PIO) Modes 0-4 support
Universal Serial Bus (USB)
* Two independent USB interfaces which are Open Host Controller (Open HCI) compliant
* Second generation proven core design
Integrated Super IO
* Floppy disk controller
* Two standard serial ports
* Infrared communications port off one of the serial ports
* IEEE 1284 compatible parallel port
* Real-time clock
* 8042 AT keyboard and PS/2 mouse controller
* Access Bus interface compatible with SM Bus and I2C
AT Compatibility
* 8259A equivalent interrupt controllers
* 8254 equivalent timer
* 8237 equivalent DMA controllers
* Port A, B, and NMI logic
Power Management and GPIO
* I/O traps and idle timers for peripheral power mgmt.
* 8 GPIO's
* Wake-up on USB
* Keyboard / mouse activity detect for screen wake-up
Processor Interface
* Suspend clock protocol with connection through North Bridge
* NMI and maskable interrupt
Electrical Characteristics
* Dual voltage device
* 5V tolerant 3.3V I/O
* 2.5V core voltage
Power Consumption (APM)
* 33MHz 627mW (251mW), 66MHz 798mW (319mW), 100MHz 956mW (382mW), 128MHz 1789mW (716mW)
Mechanical/Environmental
* Standard Part—Up to 128MHz (0 to +70C) ambient temperature
* Extened Temperature Range Part—Up to 100MHz (-40 to +85C) case temperature
* Package: 388-pin Plastic Ball Grid Array, 35mm x 35mm
EMBEDDED FEATURES:
Patented FailSafe® Boot ROM
* On-chip code
* Allows execution of multiple instruction sets: DRAM clear, Flash erase, executable load and run, etc.
* Provides permanent and fail-safe mechanism to update S/W under all adverse operating conditions
ZF-Logic
* PWM generator
- Programmable Pulse Width Modulator output (100-100KHz)
- Free running
- Ideal for switching power supplies or LCD back-light inverter control
* External memory decode logic
- Four memory mapped chip selects
- Base address and size registers
- Automatic overlap check
* General Purpose Chip Select mapper
- Four I/O mapped chip selects
* Boot strap register (can be set by external DIP switches)
- Allows customized booting conditions
Z-tag Interface
* High speed interface to download S/W
* Uses floppy interface when "Drive Select" signal is inactive
* Communication protocol is compatible with standard serial
* Can be driven by standard parallel port
* Z-Tag programming tool allows easy field upgrades
ZF-Dwdt
* Embedded application Dual Watchdog Timer (WDT) with SW and HW control of the WDT event
* 16 bit counter primary watchdog connected to SW IRQ/NMI/SMI reset by Watch Dog Timer Input (WDI)
* Second 8 bit counter output connected to H/W reset line enabled by primary counter output
* Counter values can be read anytime
* Counter enable and disable control
Software Included with IDS
* Executable image of ZFx86 port of Phoenix Rev 4.0 PC BIOS
* RedHat Linux
* Windows CE Platform Builder evaluation package
* LynuxWorks BlueCat Linux evaluation package
* ZFx86 VxWorks RTOS Demonstration
Software Compatibility
* Linux
* Most PC compatible RTOS
* DOS, Windows CE, Windows 9x, and Windows NT
am186ed rdc
what is the price for IDS and for one chip?
spi ethernet chips
What don't you try WINBOND W90N740
Look under microcontrooler under www.winbond.com.tw
pio ns9360
h**p://www.winbond.com.tw/c-winbondhtm/partner/b_2_f_8.htm
Thanks, interesting chip, but this chip:
1) Have only 1 UART
2) Do not have any high speed serial interface, as HDLC or hardware SPI
3) Only available commercial temperature range (0 to +70C)
Now as Samsing S3C4530 replacement, I choosed Netsilicon NS9360 chip.
Netsilocon promising long manufacturing life for this chip ....
am186 linux
IA186EM 16-Bit Microcontroller AMD® Am186EM
IA188EM 16-Bit Microcontroller AMD® Am188EM
IA186ES 16-Bit Microcontroller AMD® Am186ES
IA188ES 16-Bit Microcontroller AMD® Am188ES
The R88xx series MCU are designed based on the RDC 16bit, RISC architecture microprocessor with the compatibility of 80C186/188/EM/ES/ED microprocessor
w90n740 redhat
Thanks.
the zilog ez80f91 module should be a good candidate ?
Please take take a look at the following.
http://www.microchip.com/stellent/i...ckaging: - SOIC - SPDIP - SSOP - QFN (6x6 mm)
coldfire mcf5282,5272
atmel at91rm9200
is so good
Check out for Analog Devices Blackfin based boards they are cheep and good
