Coupling Matrix for Microwave filter
markito86
Newbie level 6
I am not very skilled in this field.
I should calculate the Coupling Matrix of a Pseudo-HPF for fixed parameters (Bandwidth, Return Loss, Number of cavities and Single transmission zero).
What is the mathematical procedure ?
I have read some papers and docs but they are so confused and difficult to understand.
With kind regards.
Marco
The task is not easy. Find the book by Matthaei, Young, Jones: Microwave Filters and Coupling Structures. There are many examples of filter design and comparisons of real results with calculations.
Pseudo-HPF? You mean actually a BPF but used as HPF?
Normally Coupling Matrix is used to "describe" a BPF. The matrix tells the resonator offsets and coupling connection between resonators. Mathematircally, the coupling matrix elements are related to its corresponding lowpass prototype "g-table". Once you get the coupling matrix, you realize the physical filter (microstrip, waveguide, SIW....) based on the matrix.
I have realized the procedure to calculate the Coupling Matrix, now is there a method to properly dimension the waveguide iris structure ?
