Coupling high voltage to low voltage stages
predator89
Member level 1
Denmark
I want to connect a high voltage output stage to low voltgae input stage of 2 stage op amp.
Can anyone suggest me which output stage topology would be better for this.
AMS012
Full Member level 3
India
Common source with a resistor load will give the maximum swing.
predator89
Member level 1
Denmark
Need more info on what you are trying to do with the circuit.
I am trying to build a high voltage amplifier. And i started with a low voltage input stage with supply of 3.3 V and want to connect it to high voltage output stage. So that i can get a swing of 0 to 40V AC for the input of 0 to 3 V AC.
So i have difficulty in deciding which topology to go for.
crutschow
Advanced Member level 5
Colorado USA Zulu -7
GBW doesn't tell me the frequency response required at the output.
Don't tell me what you think you need, tell me what you actually need.
Easy peasy
Melbourne
You need a diff amp circuit to convert the high o/p voltage into something your low voltage opamp can deal with, search the net, plenty of examples...
FlapJack
Advanced Member level 1
USA
I think you at least must give the input frequency, is it fixed or variable.
Audioguru
Toronto area of Canada
I do not think you want to connect a high voltage output stage to a low voltage input stage. That is saying it backwards.
I think you have an input stage that operates from a 3.3V supply and you want it to drive an output stage that has a much higher output voltage swing.
You said you want the input to be 0V to 3VAC but you did not say 3V RMS or 3V p-p. What is it?
You said you want an output swing of 40V but did not say 40V RMS or 40V p-p. What is it?
