T
treez
Hello,
On the top left of the 4th page of this article the reader is recommended to add a heavy RC snubber in order to mitigate the low-ish frequency ringing seen in the uncoupled inductor sepic.............this is bad advice..do you agree?
The only reason you would suffer such a bad ringing (in an uncoupled inductor sepic) is if your sepic converter's feedback loop crossover frequency was too near the resonant frequency of the sepic capacitor and the two uncoupled sepic inductors. You should not use a snubber, but instead should arrange it that the feedback loop crossover frequency is not near the aforementioned resonant frequency.
https://www.ti.com/lit/an/slyt411/slyt411.pdf
