Counter inferred from VHDL
kingslayer
Member level 4
Milano, Italy
Dear all,
suppose I want to increment a value at each clock-cycle in VHDL. I can do the following, in which I omitted initial and declarations:
signal counter : std_logic_vector(3 downto 0);
COUNT_UP_PROCESS : process (clk_i,rst_i) is
begin
   if rst_i='1' then
      counter <= (others => '0');
   else
      if clk_i'event and clk_i='1' then
         counter <= counter + 1;
      end if;
   end if;
end process COUNT_UP_PROCESS;
I guess that the synthesis tool is able to recognize a counter, but I have a doubt: the counter value I want is 4-bits wide, thus it takes values up to 15 inclusive; during functional simulation (e.g., using NCSim from Cadence), the value of the counter gets correctly reset to 0 every 16 clock-cycles.
My question is: will this functionality be preserved in the final implementation? I mean, is the synthesis tool able to add any extra logic to recognize and manage overflow situations? Or should I put this logic explicitely in the design?
Thanks for your attention
Cheers
you can program your FPGA board with this code.. It'll work
the code will work without any problems. The counter will reset automatically to 0 after 15.
