corner analysis in umc 0.18 um technology in cadence
sabyasachi.iitkgp
Newbie level 3
UMC 0.18 corner analysis
I want to do corner analysis in umc 0.18 um technology in caadence
the model files required for umc are
modelFile(
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/core_rf_v2d4.lib.scs" "tt")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/io_rf_v2d3.lib.scs" "tt")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/l_slcr20k_rf_v2d3.lib.scs" "typ")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/mimcapm_rf_v2d3.lib.scs" "typ")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/MM180_MIMCAP_V101.lib.scs" "mimcaps_typ")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/MM180_REG18BPW_V123.lib.scs" "tt")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/MM180_REG18_V124.lib.scs" "tt")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/MM180_REG33BPW_V123.lib.scs" "tt")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/MM180_REG33_V114.lib.scs" "tt")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/MM180_RES_V133.lib.scs" "res_typ")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/MM180_ZVT18_V121.lib.scs" "tt")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/MM180_ZVT33_V113.lib.scs" "tt")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/MM180_LVT33_V113.lib.scs" "tt")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/MM180_LVT18_V113.lib.scs" "tt")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/pad_rf_v2d3.lib.scs" "typ")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/rnhr_rf_v2d3.lib.scs" "typ")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/rnnpo_rf_v2d3.lib.scs" "typ")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/rnppo_rf_v2d3.lib.scs" "typ")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/vardiop_rf_v2d3.lib.scs" "typ")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/varmis_18_rf_v2d3.lib.scs" "typ")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/MM180_BJT_V112.mdl.scs" "")
'("/usr/local/cadence/umc/UMC_18_CMOS/../Models/Spectre/MM180_DIODE_V113.mdl.scs" "")
now there are two kind of files one containing 5 sections tt ss ff sf fs
and another type contains 3 sections
typ min max
for the first kind it is easy to determine which section to use in which corner
but for second type of files which section i should for which corner.
please help
Re: UMC 0.18 corner analysis
typ min max
please help
typ, min & max are related to (delay) times (rise, fall, propagation), so by standard, use
typ for tt, sf & fs corners,
min for ff ,
max for ss corner.
