cordic corde with error how can i solve it
mr54852
Newbie level 1
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
library ieee;
use ieee.std_logic_1164.all;
use fixed_pkg_c.all;
entity cordinate is
generic(n:integer:7);
port(x0:in sfixed(5 downto -10):="00000010011011011";
     y0:in sfixed(5 downto -10):="00000000000000000";
     z0:in sfixed(7 downto -14);
     clk,start:in std_logic;
     done:out std_logic;
     sin,cos,z:out sfixed(7 downto -14));
     end cordinate;
architecture cordinate of cordinate is
type araye is array (7 downto 0) of sfixed(5 downto -10);
type araye1 is array (8 downto 0) of sfixed (7 downto -14);
constant teta:araye:=(
 "1100010000000000",
 "0110101001000011",
 "0011100000100101",
 "0001110010000000",
 "0000111001000000",
 "0000011100101001",
 "0000000111001010",
 "0000000011100101");
 signal a,b,c,d:araye1;
 begin
process(clk,rst,start)
begin
a,b,c<=(others=>'0');
a(0)(5 downto -10)<=x(0);
b(0)(5 downto -10)<=y(0);
c(n)(5 downto -10)<=teta(n);
d(0)<=z0
for i in (0 to 7) generate
if (z0>=("00000000000000000000000000")) then a(i+1)<=a(i)-(b(i)srl(i)),b(i+1)<=a(i)+(b(i)srl(i)),d(i+1)<=d(i)-c(i);
else a(i+1)<=a(i)+(b(i)srl(i)),b(i+1)<=a(i)-(b(i)srl(i)),d(i+1)<=d(i)+c(i);
if d(i+1)<=(other=>'0') then done<='1',sin<=a(i+1),cos<=b(i+1),z<=d(i+1);
end if;
end if;
end process;
end cordinate;
FvM
Super Moderator
Staff member
Bochum, Germany
Is it asking to much to expect an explanation of observed errors?
At first sight, there are many trivial syntax errors. How about processing the compiler error messages top down, having a VHDL text book or tutorial at hand?
