Copper thickness in a PCB
Sakr
Member level 2
Cairo, Egypt
pcb copper thickness in microns
Hi all,
I am new in the field of PCB design, and there are many things I want to know
for example
When stating the Copper thikness, why we use oz. (it is a unit of mass, as I know)?
I can't understand this point if I said I need 1 oz. Cu the thickness will depend on the width to preserve a constant mass (1 oz.)!!!!!
why we don't just use mm? are there historical reasons, or some thing like that?!!!!
Regards,
Sakr
In the PCB terminology 1 Oz copper is 35 Microns, 2 Oz is 70 Microns and so on
    Sakr
The ounce term comes from the ounces of copper to plate one square foot. It is a "plating weight", not a weight for each trace or fill.
As far as a board designer is concerned, you can use the accepted thicknesses for your impedance or current calculations - 1.4mil (35micron)=1oz Cu, 0.7mil (17.5micron)=1/2oz Cu, etc.
    Sakr
