jgraygoza
Member level 1
- Joined
- Dec 28, 2011
- Messages
- 37
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- California
- Activity points
- 1,647
This question is mostly a "how possible" is to build one.
I am working on a switch and on a separate post I state my problem.
But for this one, I am just curious to know.
If I am to build an SP2T switch, broadband (0.2 GHz ~ 18 GHz), is it a good choice to use coplanar waveguide?
Or should I stick to microstrip?
Right now, I don't have a size limitation.
I can deal with that later.
First I need to grab the concept correctly.
Do I start from the Fc and from there build the transmission lines?
Also, if I am to simulate coplanar, how close to reality will the simulation be?
I know that the main focus is that the lines are quarter wavelength lines, correct?
And from there, work my way into the band.
My simulation software is MWO.
Thank you very much for reading my post.
