Do you refer to an acoustic transmit/receive link for voice transmission underwater? What does cooperative mean in this context?
I would expect situations with a direct acoustic path and indirect reflected paths that will be unstable in magnitude, phase and delay.
Perhaps you could take a page out of HF ionospheric RF communications, as that same link description could apply.
If you have a lot of time on your hands, you could implement some kind of RAKE system to try and use alternate paths to your advantage.
Perhaps analog means would suffice on the other end of the complexity scale.
Simplest might be the equivalent of a bullhorn running from a throat mike, sending end only.
Lots of choices in between, including analog modulation of a carrier and many digital schemes.
More information would be helpful.
