T
treez
We are driving twelve 40V, 4 Amp UV LED arrays from twelve 160W LED driver PCBs. (one 160W LED array per driver) The LED driver PCBs are double sided SMT boards, (all components on the top layer) with thermal vias to bottom layer cooling copper lands.
Should both the LED Driver PCBs and the UV LED MCPCB’s all be thermally coupled to the *same* water cooled heatsink? After all, the UV LED MCPCB’s will run much hotter than the LED driver PCBs, and so thermally coupling the LED driver PCBs to the same heatsink as the UV LED MCPCB's may just end up with the LED drivers running hotter than they would if the LED driver PCBs were not thermally coupled to this heatsink?
So what do you think?… is it a waste of time thermally coupling the LED driver PCBs to the same water cooled heatsink as the one that the UV LED MCPCB's are mounted on?
The LED driver PCBs do actually get screwed to protruding “platforms” of the water cooled heatsink, but we wonder if its worth actually thermally coupling the LED driver PCBs to these platforms with electrically insulating, thermally conducting heat transfer pads?
