i have a problem with our project... one of its implementation is converting wired mouse either ps2 or usb to wireless, minimum 1 meter range... the question is..is it possible? can you give me a hint sir of what will i be using.. i tried using usb to rs232 cable and connected rxtx data of the rs232 to my bluetooth module as my transmitter and used usb dongle as my receiver...and it doesnt work...
hi
doing it that way using bluetooth is not possible.
the easy way is to use the 2.4 ghz transcievers available for about 6 to 7 pounds...it is easy and you dont need it top be paired to start transmission and reception...
sorry i dont have ckt as i have not done it mysef...instead i hope u r familiarr with the pins of rs232 u mentioned earlier...connect them respectively to WIT2450M2
transciever or nRF2401A transcievers
please check out the following
RFD21733 / RFD21735 is a complete, READY-TO-USE wireless solution with it's
built-in user application interface (RFDP8). Includes RFID, ESN, Logic Switch
Transmitter / Receiver, 9600,N,8,1 Serial UART and many easy-to-use addressable
network modes. No development required at all, no RF layout, no code writing, all
features are built-in. Be up and running with a full wireless solution in minutes.
