converting square into Sin for wireless transmission???
Hisham2005
hello guys,
I need help, I'm making an fsk transmitter that should be connected to an Antenna for wireless transmission, but this circuit I'm working with, has an output of a square wave fsk, so, I guess I need to convert this square into sine for wireless transmission with an antenna, how?
the site which has the simple fsk modulator is here :
try to check the pdf version, (last page in the pdf file)
so, how i can convert it?, an RF amplifier in this case won't be sufficient!
thanks
To convert square into sine, build a low-pass filter that passes the desired frequencies and blocks everything above three times that frequency.
What frequency are we talking about here?
The simplest way to get FSK modulated carrier frequency is to FM modulate the VCO (LC oscillator with varactor diode) with a (digital) squarewave signal. But this design will probably need PLL control for frequency stability, so its complicated for unexperienced designer.
Perhaps a better way and still simple to get frequency stable, FSK modulated RF signal is to FM modulate crystal-based oscillator with a couple of multiplier stages to get higher frequencies.
I think you do not need to convert the sqare wave (modulating signal) into a sinusoidal one.
Usually RF signals are modulated from square wave using a pin diode, a varicap or a PLL Modulator.
