Oct 20, 2006 #1 E elektr0 Full Member level 5 Joined May 2, 2006 Messages 279 Helped 2 Reputation 4 Reaction score 3 Trophy points 1,298 Activity points 3,374 Hallo, when calculating the multi mode scattering matrix of a differential pair from single ended measured data, for which impedance are the common and odd mode matrices valid. If each of the the single ended line has the impedance Z0. Thanks for any reply. elektr0
Oct 21, 2006 #2 M Manjunatha_hv Advanced Member level 3 Joined Aug 3, 2005 Messages 810 Helped 241 Reputation 482 Reaction score 126 Trophy points 1,323 Location INDIA Activity points 8,689 Hello, Hare are the attached very good documents on this topic... If you are using AWR Microwave Office, then an example available at the following folder... C:\Program Files\AWR\AWR2006\Examples\Circuit_Design_Types\Signal_Integrity\Mixed_vs_Single_Ended_Data_Files.emp ---manju--- Attachments tr04jt03_1043.pdf 436.1 KB · Views: 71
Oct 22, 2006 #3 E elektr0 Full Member level 5 Joined May 2, 2006 Messages 279 Helped 2 Reputation 4 Reaction score 3 Trophy points 1,298 Activity points 3,374 thanks i will work through it. i think you will get 3 pts *g*.
