Converting from binary to hexadecimal using C18
Anthony_87
Dear all,
I need help in converting an unsigned char array[8] (that actually contains the binary bits) and convert it to a hexadecimal notation!!
for example I have something like that:
unsigned char data[8] = {0,0,1,1,0,0,1,1}
and i need a function to return the converted value 0x33
so is there any function in the C18 library that do the trick? if not, can someone help me with the code?
Thanks in advance
Best Regards
Actually, I don't know is there such as function, but it is not a problem to write it yourself.
For example, your a number in binary is {0,0,1,1,0,0,1,1}.
In hex there is two chars 0-F. So that, you need to divide yur binary number into two parts: 0011 and 0011. Then, as you can see, there's only 16 possible variants of each part. You can convert from binary to hex using this table:
binary hex
0000 0
0001 1
0010 2
0011 3
1010 A
1011 B
Then just join two parts.
anyone can easily do a switch case algorithm, but thats not the right method, lets say u have to convert a 16bit word to hex ... it just wont work !! I need to a general algorithm :/
I dont have any of my pascal source code available, but...
1) build an array CH of '0123456789ABCDF'
2) use two temp variables to hold 'high' and 'low' nybbles.
3) use two temp char variables to hold the two CH(high) and CH(low) chars.
return the 2-char value.
Easily modifiable for 16-bits...
Hope that helps!
Edit: Here is one for 16-bit values that is a bit more 'elaborate'...
MODULE DHCV;
VAR
AH : EXTERNAL STRING;
A : EXTERNAL INTEGER;
D : EXTERNAL REAL;
PROCEDURE DHCV;
VAR
X,Y : INTEGER;
X1,X2,X3,X4 : INTEGER;
Y1,Y2,Y3,Y4 : INTEGER;
N : STRING;
BEGIN
N := '0123456789ABCDEF';
Y := trunc(D);
Y1 := shr((Y & $F000),12);
Y2 := shr((Y & $0F00),8);
Y3 := shr((Y & $00F0),4);
Y4 := (Y & $000F);
AH := CONCAT(N[y1+1],N[y2+1],N[Y3+1],N[Y4+1]);
d := d + 1;
end;
something like this will work:
unsigned char i, x = 0;
for(i=0;i<8;i++)
x = x<<1;
if( data==1 )
x = x | 1;
here x will have the value formed by the binary digits.
