converting floating point to fixed point
fireblade
Newbie level 6
what are the techniques to convert Floating point numbers to Fixed Point numbers.
emanuelcsm
Member level 3
Brasil
fireblade,
What language are you trying to do this...
If is C, you can use:
float a = 2.5;
int b = (int)a; //It will retraive the integer part of the float
you can use the Ceil rotine too, it will chect the value before retreave the integer part, for example ceil(2.4) returns 2, ceil(2.6) returns 3.
pmat
Member level 5
Grenoble, France, EU
try SystemC typecasts from floating point numbers to fixed point systemC
numbers and vice versa.
They are prety handy!
Fom more details read the last chapters of the SystemC user manual...
pmat
rsrinivas
Advanced Member level 1
bengalooru
check out the matlab fixed point toolbox. it's really worth as it contains lot of inbuilt functions and also good documentation.
xstal
Full Member level 2
USA
hi,
Do you want to implement it in VHDL?
vinodkumar
Full Member level 5
hyderabad
Hi IS this requires as a part of your project you are explicitly trying for this.
bye
