Converting a 50ohm scope input to 1Meg?
dcoaster
Newbie level 2
Hi all,
I'm trying to use a microcontroller's GPIO output to trigger the scope using it's aux trig input channel (because all other channels are filled). Turns out that won't work because the aux trig input is 50ohms and the GPIO can't obviously drive it. Would it be possible to convert (using an adapter) the aux trig input to a 1Meg ohm input? Any ideas?
Thanks!
It would be unusual for an aux trigger input to present 50 Ohms resistance as a load. You can measure it easily with a Ohm meter, if it measures 50 Ohms across the input you probably only need to add a series resistor to limit the GPIO current to a safe level. If the resistance is much higher, still add a small resistance (~47 Ohms) to give a degree of isolation if the input presents a capacitive load. If you are using screened cable, put the resistor at the GPIO pin, not at the scope end of the cable. Most aux trigger inputs only need a small signal to work on, when your scope is set to aux trigger mode you should be able to set the trigger level so it is sensitive to quite small voltages.
