Convert std_logic_vector to natural
trunkpk
Newbie level 3
Newbie level 3
Spain!
[SOLVED] Convert std_logic_vector to natural
Hi, i have two std_logic_vector of 5 bits, with these i do a std_logic_vector of 10 bits. I need to convert this 10 bits vector into a natural number, range 0 to 1024.
I want to do this, to introduce the natural number in a rom and obtain the output.
But i have a lot of problems...
This is the code:
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.numeric_std.all;
ENTITY conver is
PORT ( a, b: IN std_logic_vector (4 DOWNTO 0)
END conver;
architecture con of conver is
SIGNAL aux:  std_logic_vector (9 DOWNTO 0);
SIGNAL aux1:  integer range 0 to 1024;
BEGIN
  PROCESS(a, b)
   begin
  aux <= a & b;
aux1 <= to_integer(unsigned(aux));
    end process;
end con;
But doesn't run, and other configurations neither, like conv_integer.
Any suggestion?
Thanks
what are Db and Qry? they dont appear anywhere in your code?
You need to add a,b and aux to the process sensitivity list.
excuse me, they are a and, b.
The compilation is ok, but when i have simulated, the value of aux1 is 00000 ever.
are you changing a or b only once. since you have used signals inside the process the aux1 will get assigned with a one clock cycle delay. so try something like this in the testbench:
a=16;
b=17;
wait for 10 ns;
a=32;
b=33;
oh ***! i've lost two ours in this s***
The problem is that aux1 takes the old value... but i'll solved it, I guess
Thank you very very much :)
