Convert RS-232 to USB on a old notebook
PicBlaster
Member level 1
Hi, i have a USB PIC programmer, that i want to use on my old notebook, but the notebook has no usb-port only rs-232 ports.
I have search the net, but only found some circuits for USB to RS-232.
I hope you can help me !!!
best regards
PicBlaster
checkmate
Advanced Member level 3
Toilet Seat
This is tricky. USB to Serial convertors will not work here. In order to communicate with your usb programmer, you'll need a usb host. If your laptop has a pcmcia slot, it'll be much easier to get a pcmcia usb card.
Another solution is to open up your programmer and check if it is using a usb-to-serial convertor like pl2303 or ft232 chips. You can directly tap out the serial signals.
sysco_stevens
Junior Member level 3
I think there is no chip available to
realize your intent, because these chips
has no space to live. most of us
do not need these chips. converting
USB to RS232 may make sense,
converting RS232 to USB make
no sense.
best regards
best regards
PicBlaster
4S7thilak
Junior Member level 1
Dear PicBlaster, I like to know the site you found some circuits for USB to RS232. You may write to email: thixxxx@sltnet.lk / xxxx@gmail.com
MOD: Your mail ID is removed. If you expect every member to contact you through your mail ID, why you have joiined the forum? Forum is open for all. You may share anything in open. Next time i see you asking anyone to mail you, you'll get a warning.
