[PIC] convert individual digits (from the keypads) into a single number
dorutomkat
Newbie level 3
convert individual digit (fom keypad) into a single number
I have in my mind a programable counter. When i input a digits form keypad (1,2,3,4) , it's mean i input "1234". the counter (i resolved that part), start (after i input "#" from keypad) and stop at designated number like "1234".
i try with "FloatToStr" but, i'm not sure it's work!
any help?
thank you!
P.S.
i'm rookie in mikroc!
Re: convert individual digit (fom keypad) into a single number
long value = digit1 * 1000 + digit2 * 100 + digit3 * 10 + digit4;
Or on each input:
value = value x 10 + new_input
Klaus
Thank you all, I will try, back with details!
hi again!
As expected, it not work!
I hope that I understood what you meant. I think kp+10, or kp+100, etc, is not a number!
This is part of my program:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
// pic16F877A
  unsigned short kp ;
  char  keypadPort at PORTD;
  unsigned int v;
// LCD module connections
sbit LCD_RS at RB2_bit;
sbit LCD_EN at RB3_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB2_bit;
sbit LCD_EN_Direction at TRISB3_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
// End LCD module connections
  char *digit="0000";
  void main()
   int x=1;
  Keypad_Init();                           // Initialize Keypad
  lcd_init();
  lcd_cmd(_lcd_clear);
  lcd_cmd(_lcd_cursor_off);
    do {
    kp = 0;                                // Reset key code variable
    do
     kp = Keypad_Key_Click();             // Store key code in kp variable
     while (!kp);
     switch (kp)
      case  1: kp = 49; break; // 1
      case  2: kp = 50; break; // 2
      case  3: kp = 51; break; // 3
      case  5: kp = 52; break; // 4
      case  6: kp = 53; break; // 5
      case  7: kp = 54; break; // 6
      case  9: kp = 55; break; // 7
      case 10: kp = 56; break; // 8
      case 11: kp = 57; break; // 9
      case 14: kp = 48; break; // 0
       digit[0]=kp;
       digit[1]=kp*10;
       digit[2]=kp*100;
       digit[3]=kp*1000;
       v=digit[1]+digit[1]+digit[2]+digit[3];
      Lcd_chr(1,x++,v);
      while(1);
Undocumented code.
Not saying WHAT does not work.
How can we help?
What do you want to achieve with this?
 switch (kp)
digit[0]=kp;
Lets say kp = 1
Then you make kp = 49
Then you make digit[0] = 49
** very unclear why "49"...
Klaus
