nomad13
Full Member level 3
byte to decimal converter picbasic
I am using proton picbasic and proteus.
On my circuit I use a RTC (ds1302) after getting the time from the RTC I want to compare it to a decimal number. My problem is I connot compare the two number if the value of the time is greater than 9 because after 9 the next number is 16. I am using the RTC as a counter.
My other option is to use countup or countdown timer ic but I don't know which on to use so if someone could give me another option then I'm willing to change my design.
Thanks in avance.
Thanks in avance.
