Convert C to assembly
KH
Junior Member level 1
convert c to assembly
In C command syntax, n++ is equivalent to n=n+1, but if convert to assembly will it be the same interms of code length and processing time ?
convert c to asm
Just give incerement instruction of your processor and find cycle time clock freq..... !!
convert c to assembler
That would be compiler dependent. Compiling n=n+1 as an increment instruction is one of the rudimentary optimizations, as is using a shift for a multiplication by a power of 2 and ignoring do nothing statements ( n=n+0 or n=n*1)
Some compilers have switches to control the degree of optimazation.
Compilers also usually have switches to generate an assembly listing of the code they generate. Reading this listing can be a real eye opening experience.
convert command to assembly
It will depend upon complier you using.
how to convert c to assembly
No ... Compiler has some over head .. Assembly will be faster ........
convert c assembly increment
Most of the compiler supports assembly listing use compiler switch to generate assembly see the simple inc operation produces quite a few code... it also depends on target processor .....
    KH
asm convert to
If the compiler treats n=n+1 as the syntax of n=n+x, then maybe it makes a difference, n++ only need register increment, but n=n+1 will require direct addition of a constant.
