Convert analog to PWM-signal?
Beffo
Junior Member level 2
analog to pwm
How do I generate a PWM signal from a simple voltage level.
If voltage rises I want a PWM with higher frequency.
EDIT:
I just found the LM3524, that is commonly used in switching power supplies, and can also be used i n other application.... it says in an app. note.
Can I use it to create a PWM signal based on some variabel that i can adjust during operation.
analog to pwm
Will voltage on pin 1 from figure 1 not be enough to meet your demands ?
P.S. dont upload docs from inet instead give links to them .
converting analog to pwm
Beffo,
to generate a PWM signal from a voltage level, you need to put that voltage level into the input pin of a comparator. The other input pin of the comparator will need a sawtooth with a certain magnitude and frequency. The controller IC will usually have a timing resistor and timing capacitor Rt and Ct, that will determine the frequency of the sawtooth. The magnitude of the sawtooth is determined internally by the IC.
The beginning of the PWM pulse is determined by the beginning of the sawtooth and the pulse ends when the voltage level crosses the sawtooth. If you look at the datasheet for the Comparator section you should be able to see this.
Best regards,
v_c
analog to pwm signal
OK, attachments gone :)
And OK, I understand how the PWM-modulation works.
Is it possible and a good choice to use the LM3524 to modulate PWM-signal to drive the motorcontroller-chip TB9060?
https://www.ortodoxism.ro/datasheets/toshiba/3380.pdf
PS. I want to control a sensorless BLDC ~100w, 0-10000 rpm, -40 to +~125 celsius
EDIT:
Perhaps the SG3525A is a better chioce, it is possible to adjust v-ref from outside the chip.
analog voltage to pwm
Hey Beffo!
PWM=Pulse Width Modulation.
Pulse width changes in response to input, not the frequency!!
Giri
analog til pwm
YES, of course...
It is the duty cykle/time that should be adjusted.
So how about the SG3525A? would it work together with TB9060?
converter analog to pwm
Beffo,
I had a cursory glance through the tb9060.
It just needs the PWM signal, and it generates the 3-phase bridge waveforms.
The PWM could be achieved easily using the 3525.
Just take care of the minimum and maximum pulse widths!
So good luck!
Giri
giri convert to rpm
Thanks Giri, components ordered...
who knows... maybe it will work :)
