ark55800
Newbie level 2
Hi, I am working on a project to display the temperature from a thermistor on a LCD display. Here is a list of components I am using.
HD44780
PIC18F4520
LM35cz
I am working in assembly language and my question is how to take the 10 bit ADC result my PIC gives me in the ADRES register and display it in Fahrenheit on the LCD. I am pretty much stuck as far as coding goes. Not sure what steps I need to take. Can anyone help me out? Here is my code
HD44780
PIC18F4520
LM35cz
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 Main #DEFINE enable PORTC,2 #DEFINE RW PORTC,1 #DEFINE RS PORTC,0 movlw 0x00 movwf TRISC movwf TRISD movlw 0xFF movwf TRISA Initialize_LCD BCF RW ; clear RW BCF RS ; clear so you can put in instructions movlw 0x38 ; setting up LCD for 8 bit interface, 2 lines movwf PORTD ; send to PORTD call toggle ; calls toggle which sets enable then delays, then clears enable.. (writes commands) movlw 0x38 ; must send a total of three times to the LCD movwf PORTD call toggle movlw 0x38 ; last time to send to PORTD movwf PORTD call toggle movlw 0x0F ; command for LCD display on cursor blinking movwf PORTD call toggle movlw 0x14 ; move cursor right by one character movwf PORTD call toggle movlw 0x01 ; clear LCD display and DDRAM movwf PORTD call toggle FirstMessage BSF RS ; setting RS will enable the LCD to accept data inputs movlw 'T' ; writing a L to the LCD movwf PORTD call toggle movlw 'E' ; writing an E to the LCD movwf PORTD call toggle movlw 'M' movwf PORTD call toggle movlw 'P' ; making a space on the LCD movwf PORTD call toggle movlw ':' movwf PORTD call toggle SetupRegisters movlw b'10001010' movwf ADCON2 ; setup ADCON2 to 2Tad and 32 Prescaler TOSC (3.2us acquistion time) movlw 0x00 movwf ADCON0 ; select channel 0 ADCModule BSF ADCON0,0 ; turn on the ADC module BSF ADCON0,1 ; start the conversion Conversion btfsc ADCON0,1 ; check conversion goto Conversion BCF ADCON0,0 ; turn off the ADC module movlw ADRESH ; read and move the result movwf 0x00 movlw ADRESL ; read and move the result movwf 0x01 BCF RS movlw 0xC0 movwf PORTD call toggle Insert Code for displaying conversion goto ADCModule toggle ; toggle commands into LCD BSF enable ; Make enable high call delay2 ; call delay BCF enable ; clear enable return ; return to code delay2 movlw 0x9F movwf count1 movwf count2 indelay2 decfsz count1,1 goto indelay2 decfsz count2,1 goto indelay2 return delay ; delay for 1s movlw 0xFF movwf count1 movwf count2 indelay decfsz count1,1 goto indelay decfsz count2,1 goto indelay return ; *** main code goes here *** ;****************************************************************************** ;End of program stop END
