controlling firing angle of scr
abbas1707
Full Member level 4
firing angle of scr
plz tell me how to interface silicon controlled rectifier with 8051 ??? to control its firing angle:?:
scr firing angle
refer to
:arrow:#811396
:arrow:#812567
:arrow:#812952
firing angle in scr
Dear budhy,
Abbas is asking about SCR not Traic, how to control the firing angle of SCR
firing angle scr
FYI : you can control firing angle of SCR with the same way as controlling Triac...
firing angle for scr
oooh ..... ur using MOC3021 ..... it is opto traic use to fire the traic for both cycle +ve and -ve
if we use opto triac thenin -ve cycle the reverse voltage will generate on the SCR gate then SCR may be under go in reverse breakdown region...........
that's why i am asking
what is firing angle in scr
Yous miss interpreted th graph! Negative pulse on SCR gate would not triggered the SCR, and there are no relation with "SCR may be under go in reverse breakdown region........... "
Note: the graph is VI characteristics of the SCR with gate open, not a SCR triggering characteristic!
But that is not the main point, abbas1707 is asking about controlling firing angle, not triggering circuit.
firing angle controller
if u use opto SCR then may be this problem will solve
