aditya.adi2293
Newbie level 1
Hi....
I am trying to control an led matrix(5X7) using an 74HC595 latch+shift registers and atmega32.
I checked out several codes on the internet..it was quite easy.
So i tried making up my own code using atmel studio. But the output pins show zero output whatever serial data i send.
(The multimeter showed zero volts with GND as reference)
I tried it on 6 different ic's, all giving same result.
Here is the code:
Here is the code with meaning of each assignment
Here is the code:
#include <avr/io.h>
#include <util/delay.h>
// PORTB used
// PINB7 = DataSerial
// PINB6 = REGCLK
// PINB5 = STORECLK
// PINB4 = MasterReset'
// PINB3 = OutoutEnable'
void send_high(void)
//I know delay of 1 ms is not needed..but is sufficient for my purpose
PORTB|=(1<<PINB7);
_delay_ms(1);
PORTB|=(1<<PINB6);
_delay_ms(1);
PORTB&=~(1<<PINB6);
_delay_ms(1);
PORTB&=~(1<<PINB7);
_delay_ms(1);
void send_low(void)
_delay_ms(1);
PORTB|=(1<<PINB6);
_delay_ms(1);
PORTB&=~(1<<PINB6);
_delay_ms(1);
void send_data(uint8_t data)
_delay_ms(1);
for(uint8_t var1=0;var1<8;++var1)
{ data=data<<var1;
if( data & 0x80 )
{ send_high();}
else
{ send_low();}
_delay_ms(1); //is it needed ?
PORTB|=(1<<PINB5);
_delay_ms(1);
PORTB&=~(1<<PINB5);
void main()
DDRB=0xFF;
PORTB=0x00;
_delay_ms(1);
PORTB|=(1<<PIND4);
_delay_ms(1);
PORTB|=(1<<PIND5);
_delay_ms(1);
PORTB&=~(1<<PIND5);
_delay_ms(1);
send_data(0xFF);
while(1)
#include <avr/io.h>
// PORTB
// The pin config :
// PINB7 = serial data
// PINB6 = shift clk
// PINB5 = store clk
// PINB4 = master reset'
// PINB3 = output enable'
PORTB|=(1<<PINB7); //data pin high
_delay_ms(1);
PORTB|=(1<<PINB6); //shift clk high
_delay_ms(1);
PORTB&=~(1<<PINB6); //shift clk low
_delay_ms(1);
PORTB&=~(1<<PINB7); //data clk low
_delay_ms(1);
void send_low(void)
_delay_ms(1);
_delay_ms(1);
_delay_ms(1);
_delay_ms(1);
{ data=data<<var1;
if( data & 0x80 )
{ send_high();}
else
{ send_low();}
_delay_ms(1);
PORTB|=(1<<PINB5); //store clk high
_delay_ms(1);
PORTB&=~(1<<PINB5); //store clk low
void main()
DDRB=0xFF;
PORTB=0x00; //reset register high
_delay_ms(1);
PORTB|=(1<<PIND4); //reset register low
_delay_ms(1);
PORTB|=(1<<PIND5); //store clk high
_delay_ms(1);
PORTB&=~(1<<PIND5); //store clk low
_delay_ms(1);
send_data(0xFF);
while(1)
