Control voltage variation in PLL
maharaja1989nellai
India
Hi all,
iam finished my PLL inCP90nm.After locking my PLL the control voltage variation will be 6mV...After adding Decoupling capacitor(Decap=150p) between supply and ground the control voltage variation will be reduced to3.5mV...
my questions are
1) How much value of control voltage variation is best?
2) If i need control voltage variation about uV range what to do?
3) How much value of frequency variation is best?
What is the best ?
It depends on your application requirements and your design budget.
To reduce variation you have to increase the capa of your filter.
i set my loop capacitor filter are within the Bandwidth limit(bandwidth=Reference frequency/10)...I need my PLL control variation will be uV range..
thanks
I see,
So you have to use more sophisticated filters (higher order filter, active filter, etc)
