Continuous conduction mode PFC inductor does not need Litz winding?
T
treez
Hello,
Would you agree that the inductor of the PFC stage with the current shown below in it, does not need to be litz wound, since the CCM waveform has too-insignificant harmonics?
Ie, one strand of ECW wire should be enough?
What is your requirement for THD? < 10%?
Is this over entire load and supply range?
Does SRF of inductor boost harmonics?
Reactions: treez
    T
thanks, I am speaking of losses due to skin effect, and that due to the low level of harmonics in the waveform, it obviously doesn't need litz winding.?
THD as per UK/USA regs
SRF doesn't boost harmonics in this case
Its difficult to give a definite verdict.
But you are quite right in that if the ratio of dc current to ac ripple current is large, as it can sometimes be in a continuous mode choke, then the effects of skin effect are much reduced.
But its a relative improvement, the frequencies and wire size still need some consideration.
Its really a judgement call. Back to back testing may be the only way to know for sure if litz offers a worthwhile reduction in copper loss.
Reactions: treez
    T
