Constructing a super heterodyne??
Learner
Full Member level 2
Area 621.xxx
74hc4066 mixer
Hello friends,
I am looking to construct an audio spectrum analyzer (bandwidth ≤ 20khz) using super heterodyne but I am not quite sure what part I should use, I am aware of mixer ICs on the market but their purpose are mainly focused for communication use. After reading the book Radio Frequency Integrated Circuit Design on mixers, I was wondering if it is possible to use an analog switch such as the CD4066 switching by a local oscillator as a mixer?
74hc4066 as amixer
Any thought on this approach people??
cd4066 heterodyne circuit
Yes, you can use 4066 or 74HC4066.
ahmad_abdulghany said:
I think that 74HC4066 will be more stable than the CMOS 4066,
BR
Ahmad,
Hi Ahmad,
Would you be able to clarify why this is the case? I donno what's the difference between a CD4066 and a 74HC4066.
Thanks!
I had used both before (about 3 years ago) and the 74HC4066 was much stable, CD4066 was sensitive to human approach, and touch, however you can compansate it using some pull-down high resistors.
That's a practical notice!
and i hope it helps somehow!
Good Luck :)
Ahmad,
