CONSTANT VOLATGE CONSTANT CURRENT circuit
lats
Full Member level 4
Hello friends,
can someone please help me in desigining a CONSTANT VOLATGE CONSTANT CURRENT circuit which can provide constant voltage of 36 volts & constant current of 300mA.
Thanks
Regards,
Lats
You mean current&voltage limitation.
If you connect 100 ohm resistor to your circuit what current will be flow trough this resistorand what voltage will be on this resistor?
what will this serve
Supplying a constant voltage at a constant current can only occur for one unique load resistance. Otherwise you would violate Ohm's Law :cry:
Lefty
Shurly you mean upto 300ma ( possibly to trickle charge a bank of leadacid battries)
