[SOLVED] Const shows error in sine table of a sine wave inverter code with PIC16F73
Mithun_K_Das
Advanced Member level 3
Dhaka, Bangladesh, Bangladesh
Error in wave inverter code with PIC16F73
I was trying to develop a simple sine wave inverter using PIC16F73 MCU.
Compiler: mikroC pro for PIC v7.6.0
Simulator: Proteus 8.9
//sine wave generation using PIC16F73 test
//Crystal: 20MHz.
unsigned int sin_table[32]={0, 25, 49, 73, 96, 118, 139, 159, 177, 193, 208, 220, 231, 239, 245, 249, 250, 249, 245, 239, 231, 220, 208, 193, 177, 159, 139, 118, 96, 73, 49, 25};
int duty=0;
bit alt;
void Interrupt() iv 0x0004 ics ICS_AUTO
   if (TMR2IF_bit == 1)
      duty++;
      if(duty>32)
        duty=0;
        alt=~alt;
      if(alt)
         CCPR1L = sin_table[duty];
         CCPR2L=0;
         RC0_bit=1;
         RC3_bit=0;
      else
         CCPR2L = sin_table[duty];
         CCPR1L=0;
         RC0_bit=0;
         RC3_bit=1;
      TMR2IF_bit = 0;
void main()
   TRISC = 0x00;
   PR2 = 249;
   CCP1CON = 0x4C;
   CCP2CON = 0x4C;
   TMR2IF_bit = 0;
   T2CON = 0x14;
   TMR2IF_bit = 0;
   TRISC = 0;
   TMR2IE_bit = 1;
   GIE_bit = 1;
   PEIE_bit = 1;
   while(1)
I was simulating in proteus. Still not developed in hardware.
This code is working fine in simulation:
Problem is when I'm declearing the sine table as Const proteus can't simulate it, shows:
Can anyone tell me whats wrong here?
I wonder if there's an actual problem of PIC16 performing flash program read during interrupts or it's just a simulator bug.
For the present code, there's no advantage of using interrupts while executing an empty loop. Instead you can poll timer flag in the loop. Being even faster than performing interrupt context switching.
That means it should work in real hardware, right? The while loop is blank as I just started coding. In the first step I found that unexpected error. Recently I've completed one with dsPIC based pure sine wave which was excellent. Just started a new small one with PIC16F73. Hope anyone who are looking for similar code will be benefited from this post.
The small PIC processors are not good for C compilers. As an example, they can't read from program memory, so a constant lookup table is made from an "array" of return instructions.
The indexing is done by jumping to the right return instruction.
You should look at the assembler code generated by the compiler.
If you really want to learn the limitations of the small PIC processors, you can use a non-ANSI compiler from https://www.bknd.com/
Those compilers simply don't support constructs that don't map well to the processor's instruction set.
The compiler will give an error when you do something "stupid".
I would try declaring sin_table as unsigned char instead of int once done as above waste memory filling with zero (const values are smaller than 255). As far as I remember, the PIC16F family has limitations reagarding to the size of arrays, which I would not expect to see in the above case.
OK, then what should be used for declaring sine table maybe 4-5 different one for feedback control? Using same type of array is consuming lots of RAM. What is the solution then?
I tried with multiplying with sine table. It works. Feedback possible.
//Crystal: 20MHz.
unsigned char sin_table[32]={0, 25, 49, 73, 96, 118, 139, 159, 177, 193, 208, 220, 231, 239, 245, 249, 250, 249, 245, 239, 231, 220, 208, 193, 177, 159, 139, 118, 96, 73, 49, 25};
int duty=0;
bit alt;
      duty++;
      if(duty>=32)
        duty=0;
        alt=~alt;
      if(alt)
         CCPR1L = sin_table[duty]*0.5;
         CCPR2L=0;
         RC0_bit=1;
         RC3_bit=0;
      else
         CCPR2L = sin_table[duty]*0.5;
         CCPR1L=0;
         RC0_bit=0;
         RC3_bit=1;
      TMR2IF_bit = 0;
void main()
   TRISC = 0x00;
   PR2 = 251;
   CCP1CON = 0x4C;
   CCP2CON = 0x4C;
   TMR2IF_bit = 0;
   T2CON = 0x2C;
   TMR2IF_bit = 0;
   TRISC = 0;
   TMR2IE_bit = 1;
   GIE_bit = 1;
   PEIE_bit = 1;
   while(1)
      //will add later
