abhineet22
mux + select x
Consider a 2:1 mux , what will be the output F if the Select (sel) is "X" ?
eeeraghu said:If both the inputs are 0's then the output is 0
If both the inputs are 1's then the output is 1
if both inputs are different then the output is X,
May be it depends on the simulation tool we use, dobt about this please clarify?
abhineet22 said:Consider a 2:1 mux , what will be the output F if the Select (sel) is "X" ?
