reuken
Newbie level 3
- Joined
- Nov 3, 2010
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,307
i want to understand the thought process and ideas behind these:
1 - what is the n-FET and diode (Q1 and Q2) component means?
2 - why the 4.7kOhm resistors used instead of 10kOhm like in the datasheet here (also applicable to other circuit,this is just an example to help me understand)
https://www.pololu.com/file/download/LSM303DLHC.pdf?file_id=0J564
3 - how designers verify that the component values used will yield the desired result? i mean they are only provided with IC and its datasheet,sure they need to do simulations to verify the circuit.
do they model the IC?How's the simulation done for e.g?
4 - any tut/books to help me understand better how to connect IC with external components?like from a pin of an IC with sensor/op-amp,choose values,what to consider, how to verify etc.
or IC pin as a driver.
thx
thx
