djnik1362
Full Member level 2
hi
I decide to connect an EPROM (M27C256B) to Xilinx Spartan II FPGA.
I want to know how EPROM work when a byte read from it.
As you know in most EPROMs we have CE and OE pins. (these pins are LOW enable)
What happens if i connect these two pins permanently to GND and change only
address inputs to read data from EPROM ?
The address inputs and data outputs of EPROM connect only to FPGA.
Can EPROM operate correctly if i use this configuration ?
Thanks for your support.
