Connecting eight microcontrollers using i2c
poonamkothawade
Newbie level 2
I want to connect eight microcontrollers using I2C.
I amhaving problem with connection diagram and device addresses
Can anybody help me?
thank u
FvM
Super Moderator
Staff member
Bochum, Germany
You can either use one master and seven slaves or implement a more complex multi-master scheme. With multi-master,
each peer can actively start communication, but arbitration of conflicting bus accesses is required. So the software effort is increasing.
Connect all SDA and SCL pins respectively and place pull-up resistors for both nodes. Assign unique device addresses.
arbj
Full Member level 4
how far apart are the mcus...??
