connecting different supply pins
Sakr
Member level 2
Cairo, Egypt
I have made two different parts, and I have identified the supply pins in “supply and NC” tab in the “pin mapping window” of the “pin editor” of the “Library Manager”. For the first part I used “3.3V” and in the second one I used “VDD33”. The problem arises when I want to connect those two pins. As the supply pins doesn’t appear in the symbol, I created two nets with two labels “3.3V” and “VDD33” and I want to connect the together. I use DxDesigner for schematic capture.
Of course there is an easy solution by renaming one of the pins, but is there any work around to connect the two pins without altering the naming of the pins.
Best regards
Not easily.
The best way to handle this, is have the supply pin on the symbol.
It's even allowable to have the same supply pin show up multiple times
on the schematic, as long as the pin is defined as a PWR/GND pin (example, logic symbols that have 2,4,8 gates etc)
The other way to connect two different signals together is with a Jumper symbol/part.
The cell for this symbol would be two pads that are shorted together with a drawn line instead of a trace (fooling the system, such that DRC will not report an error)
    Sakr
