Register Log in
Connecting Atmega8 directly to PC via USB
d_a_l_3
Junior Member level 1
Croatia
Hi
I have Atmega8 and I need USB connection with PC, to control LedMatrix
Now, can someone help me to realize that, I have seen many with PIC
But not USB to serial and than, I need direct methode to comunicate with Atmega(
Thanks
kishore2k4
Full Member level 5
Middle Earth
atmega usb
Since the ATMega8 doesn't sport a USB controller you have to use, either a serial/parallel connection or get a USB-serial converter which simply installs a driver on the host PC so that the whole connection will look like a serial(emulated) link so you can use just about any program to talk to your controller.
Also don't forget to use a RS232-TTL serial level translator lke MAX232.
If all that sounds to summarised you can do the following:
Get a USB-Serial converter and install it on your PC
Also use a MAX232 or similar IC as a level translator for your microcontroller(ATMega8)
Decide on a buad rate and other serial settings like pariy.
You can immediately test your code with the built-in utility program called Hyper Terminal that comes preinstalled with most windows versions.
Willebul
Junior Member level 3
Africa
atmega8 usb driver
Hi
Why not use one of the Atmel AT90USBxxx devices , It is a AVR with USB port included. Your mega8 code will run as is , just add the usb code
Wb
d_a_l_3
Croatia
atmega8 usb
Hi
Because I can't buy AT90USBxxx devices in my country...
That is problem...
:D
d_a_l_3
Croatia
atmega usb driver
I have found this on www.obdev.at
when I connect device say Device not recognized-Unknown Device
P.S.
I'm not sure if I'm doing everything well, with firmware....
If someone has made this can post firmware here???
thx
microteck
atmega8 usb rs232
hope it usedfull
didiet78
Bandung
usb atmega
Try app note avr309 from atmel
7rots51
atmega8 usb serial
use FT232R or FT245R from ftdichip ,they also provide good drivers for windows(VCP,DLL)
hosnie
Newbie level 3
usb serial atmega8
hi,
i have a program for connecting atmega8 with usb, and send data from avr to PC.
but when i debug the code with avr studio, these errors appear" undefined reference to `usbPoll, undefined reference to `usbMsgPtr', undefined reference to `usbInit'".
and when i include "usbdrv.c" in main function this is the error "undefined reference to `usbCrc16'"
this variable is in "usbdrv.c"
i am beginner, could someone help me please?
i have attached source codes.[/code]
rafei
Junior Member level 2
Tehran
usb driver atmega8
hi,
i`m using a FT232RL rs232 to usb interface and the result is good.
the only problem is making a graphical .exe program for communication with micro.
saurabh_j
Newbie level 1
Re: usb serial atmega8
hi,
hey u find anything related to it.... i am in need .please reply soon
Toggle Sidebar
