[SOLVED] Connect the core ESD power clamp to power mesh
stevenv07
Hello everyone,
could you tell me how to connect the core ESD power clamp cell to the power mesh in Cadence Innovus? There are multiple ports with the same name VDDESD and VSSEDS in the core ESD cell, but the Cadence Innovus only recognizes one pair of VDDESD and VSSESD. Then, it connects one pair of VDDESD and VSSEDS to the power ring.
My concern is how to tell Innovus to connect all ports VDDESD and VSSESD to the power mesh.
The core ESD power clamp is placed inside the core area of a chip, and it connects to the power mesh, and the power bump is also connected to the power mesh.
Best,
Steve.
check the documentation of the command that creates the global net connections. you can use the * operator to identify any set of instances or sub-instances
I applied this command to the design, but Innovus did not connect all esd ports to the power mesh.
Thanks,
Steve.
