bernych
Newbie level 1
Hello everyone,
I'm a new SoC encounter user and I've the following problem.
I have a block that needs to be connected to a pad with several signals.
So I declared the global nets as GROUND while loading the design, then I connect the block and pad pins to the right net (with globalNetConnect).
Now I imagine that the connection should be created with sroute. Unfortunatly when I try to run sroute on one of these nets, I get no routing and an open violation on the starting and ending point (this says me that the pins were correctly assigned to the global net)
I tried both with and without the parameter -blockPinToAlignedPadPin and -padPinToAlignedBlockPin with sroute, but the result is always the same.
Can someone help me?
Thanks
Bernych
Thanks
Bernych
