dyunasing
Junior Member level 3
hi, all,
I am connecting 2 Ethernet devices (one of them is a modem, the other is my DM9000B ethernet PHY). I did try the capacitor coupling method, but it did not work. It may be due to the auto-negotiation feature enabled by the devices. (**broken link removed**)
In the end, i have to use a transformer to isolate them. However, this method gave me around 5% failure rate where the MCU that connects DM9000B was not able to ping to the modem.
The DM9000B has a CT voltage 1.8V and 3.3V for the modem. The 50ohm pull up resistors are already built into the modem and i have no access to them.
I have a gut feeling of these different CT voltages causing this problem. Could anyone help to shed some light on this?
thanks.
Dyu
thanks.
Dyu
