bigworm
Member level 3
hi,
as is well known that when lna is well matched, you will get either best power delivery or best noise figure.
but now what confuses me is that , a low-input-impedance lna with S11 about -3 is simulated in icfb and I get its gain(gain1) and NF(NF1),
and after I match the lna with S11 <-10, I found that the gain is still more or less the same with gain1. so is the NF.
but I think when the lna is not matched, most power of input signal is reflected and little power is transferred into the lna, so that I think the gain of lna should be much less than the matched one. but the simulation result doesn't support this conclusion.
I wonder whether it is necessary to match the lna for any case?
