Confusion in DDR timing parameters
garimella
Full Member level 5
Full Member level 5
1.In DDR timing, there is a parameter called tRAS, denoting active to pre-charge delay, but tRAS= CL+tRCD, since it is a derived parameter, why is it listed as a critical timing factor as it will depend on worst case CL and RCD actuation.
2.What is the delay between DQS, DM and CLK.?
1) tRAS is not derived.
2) DM is centre aligned with respect to DQS. Clock should not come into this picture.
